Easy way to Daily Reboot HS4 (Hs4) on PI / Linux
    I was having issues with the Z Wave controller not connecting to my blinds after a few days and was trying to find a simple way to schedule reboots.
    Finally found a simple way and thought id share.
    Just create an event -> set to trigger at a time and use the built in restart.sh script
Name:	Screenshot 2022-01-11 114402.png
    It would be easier to resolve your problem than having to restart the system daily. Servers by nature are designed to run 24/7/365 and are only restarted for maintenance purposes. Try posting your problem here and see if others can shed some light.
      Yeah, some users report that their events disappear after reboots, so I would do as concordseer says...
      67 Z-Wave Nodes, 111 Events, 422 Devices
      Z-Wave, UPB, WiFi
      Plugins: EasyTrigger, weatherXML, OMNI, Z-Wave, Tuya, Device History
        Since the restart.sh script simply does a hard reboot (after a 20-second wait) won't the hard reboot exacerbate the current problem with the events.json file (or others) getting corrupted? Or are you betting on the fact that running the script off-hours would lessen that possibility? I need to do a nightly reboot also for other reasons. I was just going to create a cron job. But I like this method as it's easier to modify the event if needed.
          Originally posted by camauto View Post
          I was having issues with the Z Wave controller not connecting to my blinds after a few days....
          Does disabling the Z-wave plugin and then re-enabling it again also resolve the issue?
          Jon
            If so, check out Jon's restart plugin. I use it to stop and restart the Z-Wave plugin on a 3 hour cycle. Since I started doing that a year ago, Z-Wave has been very stable.
              You can try cron job.
              sudo crontab -e
              Enter this command to schedule a reboot. This command will schedule a daily reboot at 6:30am.
              30 6 * * * /sbin/shutdown -r now
                Yeah, the Jon restart plugin doesn't exist on the Raspberry PI. So this simple event works for me and easy to manage
                Basically the blinds by graber on zwave stop reporting at random and i found a reboot worked.
                  Other than for maintenance purposes, upgrading etc why would anyone want to restart a server daily. Surely the need to do this indicates bigger trouble ahead. I’ve seen this solution offered on so many times with other server applications which clearly masks underlying issues with the server setup. I know what I’d rather have. A properly functioning server that does its job without any daily intervention.
                    A common problem is RAM usage growth over time by applications running on the server. A daily restart caps the growth before it becomes a problem. Some things are beyond the control of the user and management becomes the only alternative. It really does not matter if there is a user login or application run as a service. The same issue can occur.
                      Not sure where you got that information from but restart works on every version of HS4...
                      Jon
                        I searched the Plugin directory and couldn't find it..?
                        Maybe the search is broken or it's not whitelisted to show up on PI devices?
                        I checked again today and didnt find anything with the phrase restart or called jon restart.
                          You have to look on jon00 's site to find it. He has tons of stuff. Please donate something if you find useful things. We need to support him.
                          http://www.jon00.me.uk/index.shtml
                            While JON00 contributions are outstanding, his method of distribution does not follow the norm for HomeSeer. If you are looking for a method to start/stop/restart a plugin or HS, then the mcsMQTT plugin will provide that capability. At the same time, it gives you visibility into the CPU utilization for each. You will find it via normal distribution via the HS Updater.
                              Lol... with over 100 different downloads available across HS2 to HS4, HST could never manage that in their updater. Seeing the pain/waiting times other PI authors go through to just get one PI updated etc is not for me. I like total control of what I do.
                              Jon
