The First Z-Wave 800 Controller.
    This is the first Z-Wave 800 Pi 4 interface. The library is still 7.17 beta. We use the chip ZGM230S secure vault.Click image for larger version
Name:	Screen Shot 2022-01-18 at 2.24.30 PM.png
    How is the range so far?
    67 Z-Wave Nodes, 111 Events, 422 Devices
    Z-Wave, UPB, WiFi
    Plugins: EasyTrigger, weatherXML, OMNI, Z-Wave, Tuya, Device History
      So this will be in the next batch of Z-Nets?
        The range is the same as Z-Wave 700. I use the external antenna. There is about 1500 meters.
          I can make this little board for Z-Net if there is demand. Maybe I could do that for HomeSeer if they want. The Z-Wave 800 support ARM PSA level 3 security, better range, and save battery life and most importantly, it can be world frequency. you could change the region by yourself if you use external antenna. The transmission power is 14 dBm
            Let's see first if they fixed the lockup bug in their firmware where they listen before they transmit that rjh has been having conniptions with!
              Works on Z-NET:
Name:	Screen Shot 2022-01-19 at 7.09.41 PM.png
                We will be moving to the 800 series once the chips are readily available. Right now its really hard to get any Z-Wave chips. Lead times are 56 weeks.
                  Great!
                  ZGM230S lead time is 40 weeks, but EFR32ZG23 only has 6 weeks.
                    Did I jump the gun when I bought HS' 700 series z-wave stick just a few months ago? I am not really concerned about range but future support of the 700 series controller. Or will whatever goes into the 800 z-wave plugin and whatever is underneath also apply to the 700 (except of course when the 700 HS doesn't support what the 800 does).
                    And why is the 800 coming out so soon after the 700? I believe there was a much bigger time gap between the 500 and 700. Was there some issue with the 700 so they pushed out the 800?
                      No, most of the changes with the 800 are for end devices, not controllers. So you probably won't see a difference between the 2. The biggest change is that the 800 has more flash memory for more complex end devices. The controller firmware is not that large so more flash is not needed there. The firmware for the controller looks like the 700 and 800 use the same code so the 700 should be supported just as long as the 800.
                        rjh That is encouraging. Thanks for the clarification!
                          I tested Z-Wave 800 for about 20 days, So far there is no that issue.
