HS4-Pi Frequent Reboots with Z-Wave PlugIn
    This started recently... HS4-Pi (4.2.7.0), whenever the Z-Wave PlugIn (3.0.9.0) is running, the Pi will reset/reboot frequently, sometimes every few minutes. If I disable the PlugIn, everything else runs fine. There are no errors in the Log after restart, Log content on restart...
    SOLUTION: Turn off (uncheck) "Enable Polling" under Plugins -> Z-Wave -> Config
     [LEFT][FONT=B612 Mono][COLOR=#000000][FONT=Roboto][SIZE=16px]2/2/2022 6:17:54 PM[/SIZE][/FONT][/COLOR][/FONT]
    [FONT=B612 Mono][COLOR=#000000]HomeSeer[/COLOR][/FONT]
    [FONT=B612 Mono][COLOR=#000000]Startup[/COLOR][/FONT]
    [FONT=B612 Mono][COLOR=#000000]************************************************************ ********************[/COLOR][/FONT]
    [LEFT][FONT=B612 Mono][COLOR=#000000][FONT=Roboto][SIZE=16px]2/2/2022 6:17:54 PM[/SIZE][/FONT][/COLOR][/FONT][/LEFT]
    [FONT=B612 Mono][COLOR=#000000]HomeSeer version 4.2.7.0 Edition: HomeSeer HS4 Pi Hub G2 Lite Starting Now[/COLOR][/FONT]
    [LEFT][FONT=B612 Mono][COLOR=#000000][FONT=Roboto][SIZE=16px]2/2/2022 6:17:41 PM[/SIZE][/FONT][/COLOR][/FONT][/LEFT]
    [FONT=B612 Mono][COLOR=#000000]Settings Loaded.[/COLOR][/FONT]
    [LEFT][FONT=B612 Mono][COLOR=#D58000][FONT=Roboto][SIZE=16px]2/2/2022 6:17:41 PM[/SIZE][/FONT][/COLOR][/FONT][/LEFT]
    [FONT=B612 Mono][COLOR=#D58000]HomeSeer[/COLOR][/FONT]
    [FONT=B612 Mono][COLOR=#D58000]Warning[/COLOR][/FONT]
    [FONT=B612 Mono][COLOR=#D58000]HomeSeer was not shut down successfully the previous time it was started.[/COLOR][/FONT]
    [FONT=B612 Mono][COLOR=#000000]Loading Settings[/COLOR][/FONT]
    [/LEFT]
    The log you’ve posted is of little use. Could you post what version of Raspbian you have installed along with what Linux kernel is in use and what version of Mono is installed.
    Have you tried to do a system update recently.
      Use the following commands to do those checks in a terminal session. Copy/paste each line below one at time and press return. Copy/paste the output of each command here.
      cat /etc/os-release
      uname -r
      sudo mono --version
        If you mean a Linux-level system update, no. (If needed, what's the command for that?)
        cat /etc/os-release
        PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
        NAME="Raspbian GNU/Linux"
        VERSION_ID="10" VERSION="10 (buster)"
        VERSION_CODENAME=buster
        ID=raspbian
        ID_LIKE=debian
        HOME_URL="http://www.raspbian.org/"
        SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
        BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
        uname -r
        4.19.118-v7+
        sudo mono --version
        Mono JIT compiler version 6.10.0.104 (tarball Fri Jun 26 19:59:14 UTC 2020)
        TLS: __thread
        SIGSEGV: normal
        Notifications: epoll
        Architecture: armel,vfp+hard
        Disabled: none
        Misc: softdebug
        Interpreter: yes
        LLVM: yes(610)
        Suspend: preemptive
        GC: sgen (concurrent by default)
          Close HS from the web UI and do a system update.
          sudo systemctl stop homeseer.service
          sudo apt update
          sudo apt upgrade -y
          Once completed reboot your unit and test your system again and report back
            sudo apt update
            sudo apt upgrade -y
            Wow, it had a LOT of things to update! I'm starting slowly, just letting the Zee run without any plugins for tonight, then will start turning things back on and see if it's stable.
              That didn't fix it. Zee ran fine for 12+ hours overnight with the ZWave plugin turned off. Within minutes of turning it on this morning, the Zee reset/rebooted itself
              I've submitted a Help Desk ticket...
                Probably best route. You’ll need to to turn on Debug in the plugin to help them resolve this issue. Always best to keep your system regularly updated too as you’ve seen.
                  I "might" have found the cause. When I unchecked "Enable Polling" on the Z-Wave Config page, the resets seem to have stopped (running for 18 hours without further problems).
                  Of course, this doesn't explain Why such an obscure setting is able to so reliably crash HS4 on a regular basis. I'll see what happens over the next few days, and wait comes back from the Help Desk.
                    Polling in general isn't good for a Z-Wave network as it creates too much traffic and too much polling can crash a Z-Wave interface. You shouldn't need to poll most newer Z-Wave devices so this option is best left off.
                    -Rupp
                      I've been running HS and Z-Wave for 15+ years, so maybe this is a legacy setting that finally acted up to the point of disruption. So far things are going well after a full day with Polling turned off.
                        Is there a way to assess traffic on a Z-Wave network?
