How do I Shutdown HS4-Pi from the command line?
    I have a shared battery backup so I need to be able to tell HS4-Pi to do a graceful shutdown over the network via a command line command. I'm concerned about using 'shutdown -h now' since that would more than likely pull the rug out from under HS4 without giving it time to cleanly shutdown.
    Thoughts?
    Found this:https://forums.homeseer.com/forum/ho...omeseer-solved
    I was looking at sending an MQTT message to HS4Pi and having an event run hs.shutdown but it appears that mcsMQTT supports both orderly shutdown as well as restart via message associations.
