Anyone Else using a Raspberry Pi 400?
Nice and clean. I like it. Unfortunately, I'm using a Pi400. so I'm limited in that regard. I've also found that most GPIO boards designed for the Pi4 do not work very well with the Pi400. You end of with the big "thing" hanging off the back of the Pi400. I'll probably pick up a Pi4 when they become more readily available again.
Originally posted by PFL View Post
See my HS4 Pi4, it is an Wi-Fi AP, it is HS4 controller, it is also a VPN server, NTP server and UniFi controller. The short antenna is for Wi-Fi, only 2.75cm, the tall one is Z-Wave antenna for 850MHz-950MHz.
John
Originally posted by kenm View Post
Thanks. I think I'll go with an external USB dongle if the internal antenna doesn't cut it.
Ah. Makes sense. Do you have any links to YT videos? I can't find anything on doing the mod on the Pi400, only the Pi4.
Have you done this is seen it done? I found some YT videos for doing it on a 4/4B, but I don't see the pads for an SMA connector on the 400.
TBH, I'd probably just use an external USB WiFi adapter with an antenna if it became a problem. It looks like the buster release has drivers for Realtek chips which are pretty common in external WiFi dongles.
Originally posted by PFL View PostIf you know some electronics, you can modify Pi 400 board to use external antenna. external antenna will make wifi much better.
Originally posted by SteveW View PostI have a Pi 400, and I found that its WiFi performance is quite poor. I gave up and now only use it with an Ethernet connection.
I have a UniFi network and for things like this, I force the device to a specific band and lock it to an AP. Any type of device with a weak WiFi signal can really mess with networks. The APs have a tendency to pass them around, hoping to get them better performance.
I am running a Pi4 using wifi with no issues... as the article says maybe it is more a router issue? I have an Orbi router and it tends to stick you on 5 if it can and doesn't like to move you to 2.4... which is an issue for my TV which needs the 2.4 for bandwidth.
Originally posted by Eman View PostYou should not run HomeSeer with WiFi, else : https://support.thepihut.com/hc/en-u...-WiFi-problems
Eman.
Eman.
