Question about Log
    Question about Log
    when I turn on a device from the HS4 dashboard it appears in the log as "device control" but when I switch the device locally it doesn't appear in log?
    If I turn on vebose logging I get it logged but in a wierd "HSTouch Server Debug" log. Any way of just getting simple logging even for local control?
    3/6/2022 4:03:44 PM HomeSeer HSTouch Server Debug 04:03:44:0760 ~ Value change ref:964 Address:13 9F CF 1 NewVal: 0OldVal: 100
    3/6/2022 4:03:44 PM HomeSeer HSTouch Server Debug 04:03:44:0760 ~ Value change ref:881 Address:14334 NewVal: 0OldVal: 100
    3/6/2022 4:02:03 PM HomeSeer Device Control Device: Third Floor Avrumi's Room Avrumis Room Platform to On (100) by/from: CAPI Control Handler
    3/6/2022 4:02:02 PM HomeSeer Device Control Device: Third Floor Avrumi's Room Avrumis Room Platform to Off (0) by/from: CAPI Control Handler
    3/6/2022 4:02:01 PM HomeSeer Device Control Device: Third Floor Avrumi's Room Avrumis Room to On (100) by/from: CAPI Control Handler
    3/6/2022 4:02:00 PM HomeSeer Device Control Device: Third Floor Avrumi's Room Avrumis Room to Off (0) by/from: CAPI Control Handler
    Does the Device Status change in the UI? I don't think HS logs device changes, only CAPI control actions. Try creating an event that triggers on any change to the device you are interested in. You can make the action simple like "Speak Something". Under Advanced Options, make sure "Do Not Log" is unchecked. You should see the event trigger every time the device is switched locally.
    The HSTouch Server Debug messages are HS4 telling HSTouch that a device with reference 964 has changed value from 0 to 100. (Value change ref:964 Address:13 9F CF 1 NewVal: 0OldVal: 100)
      The HSTouch messages are because you turned on Verbose logging. What exact device is this you are attempting to locally control? Does it support instant status? If not it will no trigger a change in HS without polling.
      -Rupp
