I recently upgraded my Zee S2 from HS3 to HS4. I also upgraded the SD card to 32 GB. I used the "Clean Install of HS4 on Zee S2" instructions. It took several tries, but I finally got it working.
I wanted to try restoring the SD card from scratch just in case I had to actually do it someday. Can't seem to get it to work. I tried using the "Clean Install of HS4 on Zee S2" instructions again but no luck. I can usually get to the registration page but when it gets to the "Confirm the transfer of services" step, it brings up the spinning wheel that never goes away. If I reset the Zee power, I can usually log into it. At that point I'll try to restore from a previous backup that I have stored on my PC. It appears to be running because an event sends an email to my phone telling me the system is up and running. However, there are no events or devices showing up. What am I doing wrong?
