Thanks, I just did and the one it returned Z-wave Core, showed the same version that I have installed along with the option to "Re-Install", which suggests that's what the Zee S2 has, just doesn't use the word "Core".
Guess I have to wait on the HS4 version for things to improve.
What is "Legacy-plugin" for Z-wave?
Originally posted by Rupp View PostThere hasn't yet been a complete rewrite of the Z-Wave plugin for HS4 so you use the "Legacy" plugin which is still a HS3 centric plugin. I'd recommend using the core Z-Wave plugin and forgo the Z-Wave UI as it's just a confusing wrapper around the Z-Wave plugin.
Please and thank you.
Hi All,
I just (finally) upgraded to HS4 on my Hometroller Zee S2 (after ditching the last of my ancient X-10 devices).
I've been having some (incomplete) pairing issues with a new Aeotec Siren 6 and noticed in my Log screen, that everything Z-wave related is referred to as "Legacy-plugin".
Is that normal for HS4?
My system info is as follows - does anything seem out of the ordinary??
Thanks in advice.
Date/time=4/28/2022 4:04:58 PM EDT
Version=HomeSeer HS4 ZEE S2 (Upg from HS3ZS2) Edition 4.2.11.0 (Linux)
MONO Version=Mono JIT compiler version 5.16.0.179 (tarball Thu Oct 4 13:39:39 UTC 2018)
License=Registered
Confguration File=/usr/local/HomeSeer/Data/HomeSeerData.json
Uptime=0 Days 14 Hours 58 Minutes 55 Seconds
Lan IP=192.168.15.10 (HomeTrollerZeeS2V5)
Device Count=256
Event Count=236
Plugins Enabled=EasyTrigger:,EnvCan:,Z-Wave:
Modules/Threads=85 Modules, 77 Threads
Available Threads=399
HomeSeer Memory Used=103 Mbytes
Plugins Installed=EasyTrigger 3.0.0.74,EnvCan 3.0.0.25,Z-Wave 3.0.10.0
Disk Size=28.97GBTags: None
