Incorrect Time
    Incorrect Time
    I noticed that the time shown in Setup on my RPI is off by 4 hours. The location is set correctly. Is there a way to fix this without having to reflash the SD card and start over?
    Thanks.
    What version of HS4 are you running on your RPi?
    -Rupp
      4.2.11.0
        Found a post with code to fix the issue. Everthing is now fine.
          I think I'm having the same issue. Could you please share the link to what you found that helped?
            This worked for me:
            https://forums.homeseer.com/forum/hs...troller-zee-s2
