sudo ps -eaf |grep xsp4
/usr/bin/mono /usr/lib/mono/4.5/xsp4.exe --port 8084 --address 0.0.0.0 --appconfigdir /etc/xsp4 --nonstop
If this is your first visit, be sure to check out the FAQ. You must register before you can post.
IMPORTANT: Your first post will be checked for appropriate content. This may take a bit of time.
sudo systemctl stop mono-xsp4.service && sudo systemctl disable mono-xsp4.service
pi@HS4Pro:~ $apt-cache depends mono-complete mono-complete Depends: mono-runtime Depends: mono-runtime-sgen Depends: libmono-2.0-1 Depends: libmono-profiler Depends: mono-utils Depends: mono-devel Depends: mono-mcs Depends: mono-roslyn Depends: mono-csharp-shell Depends: mono-4.0-gac Depends: mono-4.0-service Depends: monodoc-base Depends: monodoc-manual Depends: libmono-cil-dev Depends: referenceassemblies-pcl Depends: msbuild Depends: ca-certificates-mono Suggests: mono-llvm-support
dpkg -S /usr/bin/mono /usr/lib/mono/4.5/xsp4.exe
pi@HS4Pro:~ $apt-cache rdepends mono-xsp4 mono-xsp4 Reverse Depends: mono-xsp |monodoc-http mono-xsp |asp.net-examples |monodoc-http |asp.net-examples pi@HS4Pro:~ $ apt-cache rdepends monodoc-http monodoc-http Reverse Depends: |monodoc-manual |monodoc-manual pi@HS4Pro:~ $ apt-cache rdepends monodoc-manual monodoc-manual Reverse Depends: mono-complete ....
sudo apt remove mono-xsp4
sudo apt install mono-xsp4
