HS4 (pi) and Cync by GE
Since Cync is Alexa compatible, you might be able to bring the devices into Alexa and trigger them via Alexa routines, which could be triggered by HS4. Unfortunately, it's not local control.
I see a bit of chatter over on the Home Assistant community forums and the Node-RED forums but nothing concrete. It appears to be bluetooth which probably means you have to use a device (i.e. with the app) to control it. Seems doable with a computer with BT, but someone has to crack the protocol.
New to HS4. I've already got a lot of automation built into my house but obviously I went about it the wrong way.
I cant seem to find any info about using Cync by GE with HS4. I've got a bunch of "cee by ge" bulbs that are "Cync by ge" now but cant seem to find any info on it at all in relation to HS4.
Any help would be greatly apprecaitedTags: None
