Changing the name on my controller/system
  • bryan
    Thank you! Of course it is hidden in Custom and not in General.
  • drhtmal
    Check out the custom tab in the setup menu
  • bryan
    Thanks! This is actually to change the name that the HomeSeer controller displays up through MyHS. I have two systems now and upgraded to a paid subscription for MyHS. I was able to successfully change the name of the Pi but it seems the system name does not propagate that system name up through the stack.
  • PFL
    The best way is on your terminal on Mac or cmd on windows 10, 11.
    try ssh homeseer@HS4PiV3
    sudo raspi-config
    then you will see
    Then select 1 and you will find how to change the host name.
  • bryan
    started a topic Changing the name on my controller/system
    Hello,
    I have two HomeSeer controllers and went ahead and paid the $25/year to support both of them through myHS. I am trying to figure out how to name each system. Right now it is "HS4PiV3" and "HS4 Web Control". Understandable default names, but I would like to name each location.
    Using the Linux Tools, I changed the name using
    sudo hostnamectl set-hostname ....
    but I guess not surprising, it has no effect.
    Any help would be greatly appreciated.
    Cheers,
    Bryan
