I am new to the Homeseer Family and home automation. Recently purchased a HS4 Pi to begin automating some of the functions in my house. First is to manage my door locks. I have the Schlage BE469ZP locks with Firmware Version 0.10.9. My HomeSeer is a HS4 Pi Hub G3 Version 4.2.16.0. To install the lock on the HS I do Devices -> Add New Device -> Z Wave. I press the inclusion button on the lock. When prompted, I enter the 5 digit DSK code for the lock. The lock is discovered, but not detected as a lock. It seems to be just a generic Z Wave device with no function. What are the additional steps required to make this work? Thanks
Schlage Locks with HomeSeer HS4 Pi Hub G3
Thanks for the ideas Rupp. Yes, I does seem like there are some errors (log below). I have tried this now on two identical locks with the same result. One had firmware 0.10.9, the other 0.11.0. The locks are learned as a "Sigma Entry Control" and have no functions. I also have some graber z-wave blinds do not connect either. They are not even detected with I put them in to inclusion mode. I have moved the Homeseer right next to the door, about 1m away, and no change in results. Could it be a z-wave module failure on the Pi?"
10/27/2022 4:10:42 PM Plugin Debug GetDeviceWithFeaturesByRef - devRef : 35 - found Sigma Entry Control
10/27/2022 4:10:35 PM Legacy-Plugin Z-Wave Node 5 Z-Wave Sigma Entry Control supports having its date/time set. Current TimeZone is MDT with a UTC offset of -6h, 0m and a Current UTC time of 10/27/2022 10:10 PM
10/27/2022 4:10:32 PM Legacy-Plugin Z-Wave Node 5 is a Z-Wave Plus node. Retrieving ZWPlus Info...
10/27/2022 4:10:32 PM Legacy-Plugin Z-Wave Node: 5 Supports Class(es): ZWAVEPLUS_INFO, SECURITY, SECURITY_2, TRANSPORT_SERVICE_V2, SUPERVISION, TIME_V2, APPLICATION_STATUS
10/27/2022 4:10:32 PM Legacy-Plugin Z-Wave Warning If this is an import, you may need to remove and add the device as some devices cannot be added with an import.
10/27/2022 4:10:32 PM Legacy-Plugin Z-Wave Warning Failed to get a SECURITY SCHEME or verify the key from node 5. Device may not be added properly to HomeSeer.
10/27/2022 4:10:32 PM Legacy-Plugin Z-Wave Error Z-Wave was unable to negotiate a compatible security scheme with node 5
10/27/2022 4:10:19 PM Legacy-Plugin Z-Wave Adding using S0 Security, Negotiating or Verifying SECURITY SCHEME for node 5
10/27/2022 4:10:19 PM Legacy-Plugin Z-Wave S2 Security key negotiation failed, node cannot be added using S2, will try S0 or unsecure...
10/27/2022 4:10:13 PM Legacy-Plugin Z-Wave Negotiating Security S2 for node 5
10/27/2022 4:10:13 PM Legacy-Plugin Z-Wave Warning Node 5 does not support the manufacturer specific command class - it is either a really old device or there was a communications problem.
10/27/2022 4:10:13 PM Legacy-Plugin Z-Wave Synchronize nodes finished. Number of device nodes to be created/added = 1
10/27/2022 4:10:12 PM Legacy-Plugin Z-Wave HS-ZWPB700: Controller firmware version: 7.17
10/27/2022 4:10:10 PM Legacy-Plugin Z-Wave Done. Node 5 Added.
