Date in correct format
    How do I get the date to display in the correct format - dd/mm/yyyy? Thanks
    Malcolm
    So this is driving me mad. I've spent ages Googling. Raised a support ticket. Followed these instructions but still, the date is showing as mm/dd/yyyy. Someone must have found a way to fix this
    Malcolm
      There is no correct format. There is a format that most people used to. You could try this to your format:
      date +"Day: %d, Month: %m, Year: %Y"
      the %Y character is replaced with the current year, %m with month, and %d with the day of the month​
        These are the most common formatting characters for the date command:
          • %D – Display date as mm/dd/yy
          • %Y – Year (e.g., 2020)
          • %m – Month (01-12)
          • %B – Long month name (e.g., November)
          • %b – Short month name (e.g., Nov)
          • %d – Day of month (e.g., 01)
          • %j – Day of year (001-366)
          • %u – Day of week (1-7)
          • %A – Full weekday name (e.g., Friday)
          • %a – Short weekday name (e.g., Fri)
          • %H – Hour (00-23)
          • %I – Hour (01-12)
          • %M – Minute (00-59)
          • %S – Second (00-60)
          Where is the date displaying in the non-local format?
            I don't know where this would be applied?
            Malcolm
              Here
              Malcolm
                You need to adjust your locales to reflect your location. Do a bit of searching along the lines of this thread https://forums.homeseer.com/forum/hs...-non-us-locale
Name:	Screenshot 2022-11-27 140615.jpg
                  Thanks. Already tried that. It doesn't work. Log still shows incorrect date.
                  Malcolm
                    I stand corrected. If i untick the "Use 24 HR Time Format" in the Log Settings in HS Setup then the log entries show the correct format dates (and 24 hour times!). Could they make it any more difficult?! The joys of using a product not designed for use outside the market it was developed in I guess.
                    Malcolm
                      As a long-time European user of HS, I have come across date format problems since the first version of HS.
                      It is always a pain to have things corrected, as for the camera/recording page, of the HS4 version.
                      Also there has been no plan to support "foreign languages", for the GUI, the plugin SDK, and for the help files.
                      I really feel that nothing has ever been done, even with the help of non-english contributors, that could easily been found.
                        The 24 hour tick-box was added later as a feature request. I bet that the entire date & time was converted to 24 hour which included the date forced back to MM/dd/yyyy, regardless of the regional format selected on the Rpi. In my mind a bug which rjh should address.
                        Jon
