Under Setup / Network / Wifi Settings there is a long list of available networks in double quotes. Why? Are you supposed to be able to pick from that list? I have 20 listed, and many of them are listed twice or three times. Why is that?
WiFi networks
I don't see that [my HS4 system is cabled], so I'm gonna guess. You are probably seeing every network around you... yours, your neighbors, etc. Some may be duplicated if the WiFI router is capable of using more than one band. I see about 20 with my cell phone, but the vast majority of them are not on my property and are secured. Can you communicate with your hub?HomeSeer Version: HS4 Pro Edition 4.2.19.0 (Windows - Running as a Service)
Home Assistant 2024.3
Operating System: Microsoft Windows 11 Pro - Desktop
Z-Wave Devices via two Z-Net G3s
Zigbee Devices via RaspBee on RPi 3b+
WiFi Devices via Internal Router.
Enabled Plug-Ins
AK GoogleCalendar 4.0.4.16,AK HomeAssistant 4.0.1.23,AK SmartDevice 4.0.5.1,AK Weather 4.0.5.181,AmbientWeather 3.0.1.9,Big6 3.44.0.0,BLBackup 2.0.64.0,BLGData 3.0.55.0,BLLock 3.0.39.0,BLUPS 2.0.26.0,Device History 4.5.1.1,EasyTrigger 3.0.0.76,Harmony Hub 4.0.14.0,HSBuddy 4.51.303.0,JowiHue 4.1.4.0,LG ThinQ 4.0.26.0,ONVIF Events 1.0.0.5,SDJ-Health 3.1.1.9,TPLinkSmartHome4 2022.12.30.0,UltraCID3 3.0.6681.34300,Z-Wave 4.1.3.0
Well, this is odd!HomeSeer Version: HS4 Pro Edition 4.2.19.0 (Windows - Running as a Service)
Enabled Plug-Ins
Apples and Oranges. Best practices would have a wired connection between your HSx server and a wireless router. Your wireless router forwards commands through a WiFi connection to the LIFX bulbs. Your computer isn't talking directly to the bulb. The "backbone" of your network really should (IMHO) be cabled. Are you looking in the router (through your computer) and finding a gazillion networks? In a populous area, that is pretty much normal. Are you seeing these networks in the LIFX plugin [I'm not familiar with it.]HomeSeer Version: HS4 Pro Edition 4.2.19.0 (Windows - Running as a Service)
Enabled Plug-Ins
Originally posted by ewkearns View PostApples and Oranges.
Are you saying we shouldn't have this option?
Originally posted by ewkearns View PostBest practices would have a wired connection between your HSx server and a wireless router.
Originally posted by ewkearns View PostYour wireless router forwards commands through a WiFi connection to the LIFX bulbs. Your computer isn't talking directly to the bulb.
Originally posted by ewkearns View PostThe "backbone" of your network really should (IMHO) be cabled.
Originally posted by ewkearns View PostAre you looking in the router (through your computer) and finding a gazillion networks? In a populous area, that is pretty much normal.
Originally posted by ewkearns View PostAre you seeing these networks in the LIFX plugin [I'm not familiar with it.]
Malcolm
OK, I don't have the options that you have. Since my computer is cabled to:
1) the WiFi modem (which is broadcasting both 2.4 and 5 GHz Wifi) and serving up DHCP and DNS
2) my Z-Net for Z-Wave
3) my RaspBee for Zigbee
DHCP options are not presented to me, except in the router, nor am I presented with different bands and SSIDs outside of the router. I don't really understand the topology of your network.
I think the big thing is that if your HS4 is talking to the WiFi router at 5 GHz and the bulbs are at 2.4 GHz, that amounts to 2 different SSIDs, unless your router can sync the two bands (and you have done so). I suspect that if you use 2.4 GHz for everything, things will connect. Most WiFi doo-dads like switches and dimmers are designed to ONLY use 2.4 GHz.HomeSeer Version: HS4 Pro Edition 4.2.19.0 (Windows - Running as a Service)
Enabled Plug-Ins
