Trane z-wave themostat reading 10 degrees high since upgrade to 4.2.19.0
    That kind of says it all. I upgraded manually from 4.1.9.0 and everything but this seems fine.
    Mike B
    Doesn't say which thermostat.
      Did Trane make more than one z-wave model? I don't have the model # handy, but I think I found the problem. It didn't have a polling schedule, so probably would have updated when the temp changed, but I set it up for a 1 minute poll and it seems fine now. Thanks!
      Mike B
        They made the XR524, the XL624 - which I have. I have the temp polling set to 20 minutes, but it does auto update the temp upon change.
        Glad to hear you found a solution.
          10 degrees seems a bit a lot but in the menu you can dial in some corrections. I am not sure if it goes all the way to 10 degrees off, though. Also the XL624 can be configured to use the built-in sensor (default), the build-in sensor and external sensor or only external sensor (which is what I am using). One of the two always resets this to the build-in sensor when there is a power outage so then it's off a lot as the thermostat is in the garage.
