You can no longer define a SONOS speaker as a target for an announcement. If the device $SONOS$Livingroom$ was imported from the database, it works properly but if you need to define a SONOS device there is no option like in HS3.
HS-425 - Speak Something SONOS Selection
I am having the same issue version 4.0.1.30. There use to be a TO: option in HS3 so you could type in a custom speaker client. Maybe in HS4 plugins need to report their speaker clients as such to homeseer so they can be selected like the chromecast plugin does. For backwards compatibility I would think it needs to be there.
I read that Sonos devices are now timing Google Assistant and will work as a Google Home unit. Maybe try the Chromecast plugin? I don't have one to try it with else I would.Karl S
HS4Pro on Windows 10
1070 Devices
56 Z-Wave Nodes
104 Events
Originally posted by rotunnoe View PostWhen I installed HS4 version 4.0.1.28 none of the Sonos devices appeared in the Player Table. Is this still the case with the latest version? I play wav files via events so having Sonos work properly is important to me.
The topic here discussed is that HS4 dropped the capability to add your own speakerclient and the work around for now is to pull up the HS3 (old) page by manually adjusting the URL to ip/events.html.
Given that this topic received a fault tracking # HS425 means that the HS team is working on it, and when it disappears here, it will show solved status and you'll know that the latest released version has the solution in it.
Any progress on solving this issue. I have turned HS4 events every which way but loose and still cannot get TTS to any speaker. Oddly enough some of the announcements imported during the initial HS4 installation still work and the log showes the $SONOS$ speakers that were called from the imported event however, no joy with some of them or with newly created events.
Ed
Has this been resolved yet?
Using HS4 4.1.1.0, having recently transferred across from HS3. My existing Sonos announcements from HS3 all continue to work correctly, but I can't add a new Sonos announcement, as the option to add my Sonos link group is not there.
I tried copying an existing, working announcement, but the Sonos option disappeared when I tried to change the announcement.
Dave
