HS-534 - Energy Screen is missing graph settings
    [Windows] In Tools => Energy, not able to change any of the options. Graph Type, Select Devices. I am receiving values from the Aeotec Home Energy Monitor in the Devices View. Interestingly HSTouch does display the two graphs properly that I had set in HS3 before upgrading to the Beta.
    check in linux! there is no option to create or modify!
      sorry I don't use this function. What options did you use with HS3?
      Also, please please please... https://forums.homeseer.com/forum/de...e-topic-titles
      Learn About HomeSeer
        in hs3 you can create and modify your tables.
        ex: do a 12 hour zone with a single device
        you can put on 6 me or whatever! you can also change the table style. !
        it allows you to display them directly on your hstouch for the view in kw / h over one or more hours!
          logged
            Thanks. I think you see the problem. On the Energy Screen there are no control points available to actually select the options for the Devices to monitor or to select the graph types.
              This problem still exists in 4.0.4.0 beta.
                And in HS3 as well... The energy section in the View menu does not give you the choices to chose WHAT devices you want to include in the energy monitoring solution.
                Transitioning to HS3Pro .298 - WinXPEmbedded
                Hometroller S3 Pro - WinXPEmbedded - HSP 2.5.0.81 - BLStat - HSPhone - HSTouch Srvr 1.0.0.73 - Touchpad - BLLan - BLOccupied - DSC Plug 2.0.0.14 - BLStat .38
                  Surprisingly, go to http://myserver/energy (without the .html) and see a perfectly functioning page.
                    Wonderful! Now how to change menu link Tools / Energy?
                      Jon00 developed this method to create custom links. You can't change the HS4 Energy link unless you hack HS4 but you can create your own links. Many people created links to the legacy HS3 pages so that appear in the HS4 menu in their own location on the menu.
                      https://forums.homeseer.com/forum/3r...for-homeseer-4
