It is not possible to change the graphic image of the root device. Is this by design?
    I do not see a way to change the graphic image of the root device. Maybe I am missing it. Is this by design or will I be able to do this in a future update?
    Which image? The device image or status image? They both can be changed.
    Here I have changed both
    HS4 Pro, 4.2.19.0 Windows 10 pro, Supermicro LP Xeon
      It looks like you are using the HS3 interface, which I am able to do add well. Three issue I am having is with the HS4 interface.
        My bad! I didn’t pay attention to the forum when I replied. Since the Status/Graphics tab is still a work in progress, this is obviously not settled yet.
Name:	Screenshot_2020-02-29 Devices.png
          I can change the graphic image ok, using Device - Status Graphics tab
            Yes, but the OP wants to change it on the root device, which is not possible now.
              No progress on this? The whole root / feature setup seems to still be a mess which destroys any sensible display.
              (and I really like the new display, but the whole "we think we know what you want to display" thing is rubbish)
                You can still get to the old HS3 style device list on HS4 by entering http://<your hp4 ip>/deviceutility I use it to change the graphics to something (. I.E. the old icons still on the drive) not in the new prepared list of icons for HS4 However, it allows you to select a new graphic for the root but it doesn't seem to stick. It does allow you to change the graphics for the child's devices. Admittedly, I didn't spend much time on it.
                  It doesn't show V4 devices - but I found that you can use the full link https://<your ip>/deviceutility?ref=<device ref>&edit=1 to directly edit them
