I am getting the following error when I try and call any scripts? I can see and edit the scripts in my event but unable to run any scripts.
cant run scripts?
Originally posted by Paul32 View Post
I have the same problem, the deafault user is admin.
Homeseer Error Compiling script Jon00LinksHS4ASPX.vben:
Anny idea? (I’m on Linux)
Originally posted by jon00 View Post
The reason I asked is because that script cannot be run from an event. It is run to generate the setup web page. Do you still get the error if you call /Jon00links.html ?
My mistage, I had to use Jon00LinksHS4.vben in the event.
The manual says: Create a manual event to run the script Jon00LinksHS4.vben. Call it something like “HS Links Update”.
But still no page
404
The page you are looking for does not exist!
So we gave you this very boring substitue instead!
Originally posted by jon00 View PostIf Startup.vb is not working, there is clearly an issue with your HS4 installation. Have you updated to the latest version of Mono?
VBNC error is also a mono issue.
Normal fix is to go to usr/bin and open vbnc in an editor.
change vnbc.exe to vbc.exe
Mono JIT compiler version 6.8.0.105 (tarball Tue Feb 4 21:51:48 UTC 2020)
And this is in my VBNC file:
#!/bin/sh
exec /usr/bin/mono --gc-params=nursery-size=64m $MONO_OPTIONS usr/lib/mono/4.5/vbc.exe "$@"
