TeleFragger's start to HS4 Beta
    #16
    The change C to F should be configured on the RFXCOM General config page.
    To switch from the HS3 view to HS4 is only necessary while you configure the device and not for normal use so I guess there is not an urgent need to upgrade the plugin to HS4 for additional cost.
      #17
      as i set things up, im tagging the plugin owners... just so they see...
      seems to be working. ill go and check the general config. didnt see it initially but i need upgraded glasses and eye dr is closed..
        #18
        BLRoombaWifi
        Cheated on this one.. didnt feel like reading the docs as someone else said they just copied over their files..
        did this too and setup!!!!
          #19
          BLRoomba.. Im going to have to redo. I think just copying the stuff over didnt work. all items show but no updates
            #20
            Onto WeatherXML...
            went pretty smooth and quick.
            I added the devices to the device page, but having a user page, i dont really see me needing them so have to decide if I want all that on this page or not.
              #21
              apparently, i just dont know what im doing.. hah...
              i couldnt get an event to go for my concord 4 stuff but I was hooked up by concordseer as he showed me one of his events... and yeah.. all squared away...
                #22
                now that concordseer straightened me out... and im good..
                got the emails done for alarm.
                Got a message in there about email variables as im using $date and $time but curious how to do disarmed by...
                  #23
                  Instead of all the ifs in your logic you basically have the default disarmed condition. Once it changes from disarmed you need to send a message so that gets rid of all the ifs. A binary choice. So if condition becomes disarmed send a message. A lot simpler
                    #24
                    thx will later... workin on bathroom now..
                    how bout concord variables?
                      #25
                      Originally posted by TeleFragger View Post
                      ok
                      BLBackup setup... used this in HS2 and never did it again in HS3..
                      so time to set it in HS4...
                      works like a champ...
                      thx Blade
                      Silly question (no silly answers!) - why do you need to use BLBACKUP? I get the impression that you see this as a 'must have'... Curious!
                      and BTW - keep up these good posts, I am waiting for the 'tipping point' on HS4, but haven't seen that evidence yet.
                      Andrew
                        #26
                        What exactly do you want to do.
                        I suggest you break down your events into a number of simple logic events. You’re only slowing down the execution of events with all those “ifs”.
                          #27
                          Andrew
                          Because of situations like mine. Windows rebooted because it wanted to install some updates. Afterward ALL my event disappeared Unfortunately, I didn't use BLBACKUP. Should have.
                            #28
                            Mmmm - since I moved to Linux from Windows Server 2003 I have had ZERO problems with stability. Almost seems non-intuitive that you would have to use your Home Automation system to protect you from your own Home Automation system....
                              #29
                              LOL
                                #30
                                Thats your problem.. you went from server 2003 to linux.. im running hs3 on win10 pro 1909 with zero issues. have been thus why i have been gone from the forums for almost a year.
                                then hs4 beta was coming out and i started by setting up a server 2019 1809 box... and its running like a champ too...
                                so its more than just blbackup for little stuff... what if i uninstall plugins, or make changes, or do anything... i may never need the blbackups... but why not have it..
                                murphys law.. if you dont have backups you need them.. if you have them.. i will never bother you..
                                another example.. my neighbor got ticked at his old snow blower... txt me cuz i help him work on it every year.. said u want it. im gonna walk it to the curb.. i said sure.. so i did to it what i told him.. take it apart and pressure wash it... there was shredded belt, melted rubber stuck inside and was making the clutches not engage enough and throwing the belt..
                                since i got it, i pressure washed it and cleaned it... IT HASNT SNOWED TO USE IT IN 2 YEARS!!!!!!! so thats a good thing.. LOL
