I installed the latest HS3 on a freshly installed windows 10pro.
nothing else installed.
i activated the HS3 and copied the whole folder over from my running system ( different machine).
i tested the HS3 install and it seem to work fine.
i went ahead and updated to the latest HS4 beta as described in the post about updating to HS4 (installing it into the HS3 folder after removing the HS3 install but not the data.)
all kind of seemed to work except the energy logging.
i turned it off n the original HS3.
so I turned it back on in the settings but it didn’t seem to work, I checked the log file and it stated something like “ couldn’t add received energy data”.
i decided to reboot the whole system and the errors didn’t return.
however, when I go to energy.html, nothing shows up.
the page never populates.
i logged in remotely (headless system) and found that the cpu usage of HS4 is over 30% instead of the usual 2 to 5%.
i thought I just have to wait till homeseer generates a database or goes thru log files to populate the energy page.
so after a while the HS4 started to respond to other pages but the energy page never populated.
the second time I tried to get the energy to show up, the system did not recover. I tried to log in remotely to the system and found that the whole pc is powered down.
the pc is set to boot up after power cycle.
so I tried to boot up again but I can’t log in with teamviewer.
I have to get the pc and hook it up to screen and keyboard to see if it indeed doesn’t boot or if teamviewer and HS4 isn’t running.
i know it is a beta and I was expecting some issues but to “kill” the install just by calling the energy.html page is not really helping me in getting confident with homeseer to get this going in a foreseeable future.
