create virtual devices
    ok maybe i dont get it..
    but if I click Devices, Add
    only Virtual shows up which is what I want so I select it. Inside the device it is just X10.... what if I want to create a virtual device ^1
    am I missing something?
    Bugman1400 ... didnt want to off track your thread... i see you created 3 virtual devices... how did you do that?
      anyone?
        Originally posted by TeleFragger View Post
        anyone?
        In the devices view press the "+" button.
        Maybe add a screenshot for clarrification.
        John
          well maybe i left it to vague?
          ok so i
          Click Devices
          Click +
          only virtual device shows - which is what I want.
          I then click on it and on the next screen I get what you see below.
          I want to create a virtual device as ^1
          but since only x10 tab shows up, i can only set X10 values and I still use X10...
            ok so i
            Click Devices
            Click +
            You can ignore that X10 tab. In my case I have a Modbus tab. But when you continue the device will not be linked to that.
            rjh
            Please log
            ___
            John
              rjh
              Please log
              ___
              John
              will try again... and leave X10 blank.. and see what i get next.
              Thx!!!!
                so maybe im not understanding.... which is most likely it.. hah..
                so are we saying.. there is no longer a need to enter device codes?
                so we can just create virtual devices and not worry about giving say ^1 or {2 or anything?
                we can create devices and events will work off of them then?
                i forget what i wanted to create, but it will come back to me when i get back into this...
                but just create a device, give name, floor, room and boom... all good no need for house code..
                  Your deduction appears correct. My new virtuals are up and working with just has a reference ID and has no code attached to them.
                  HS4 Pro Edition 4.2.5.0 running on Lenovo ThinkCenter & Debian Linux
                  Plugins: Z-Wave (via Nortek USB stick
                  Home Assistant 2021.10.6 running on HA "Blue" ODROID-N2
                  Add-ons: Android Debug Bridge, Duck DNS, ESPHome, File Editor, Glances, HA Google Drive Backup, InfluxDB, Log Viewer, MariaDB, Mosquitto broker, NGINX SSL Proxy, Node-RED, Portainer, SSH & Web Terminal, Samba, TasmoAdmin, UniFi Controller, Visual Studio Code, WireGuard, Zigbee2mqtt, Z-Wave JS to MQTT
                  Integrations: AccuWeather, Alexa Media Player, Glances, Google Nest, HACS, HomeSeer, Insteon, IPP, Life360, Local IP, Logitech Harmony Hub, Mobile App, MQTT, My Garage, OpenWeather, Spotify, Tuya Local. Ubiquiti UniFi, Z-Wave JS
                  Insteon: 2413S Dual Band PLM
                  Zigbee: zzh! CC2652R Rev A
                  Z-Wave: RaZberry daughtercard on RPi 1B via ser2net
                    My virtual always just worked even in HS3. I would opt to change wording or add other ranges but the basic On/Off always worked right off the bat.
