One event having 21 icons that you could possibly click on? This is the new easier to use version designed for people seeking simplicity in their lives. Then there's the advanced options. Why do I have small up/down arrows to adjust time but not on the main event screen?
Can you imagine?!?
I realize the HS3 version of the same event has only one less icon. But look at the two side by side and this layout just looks like a waste of space and certainly not intuitive.
And you can't even see if there are any advanced options being used until you open another window. At least HS3 has a check mark.
- Likes 1
There's always someone who will not like something. Its not like you are sitting looking at it all day. You will use it once every now and then.
If you do want to do something about it then add it to the tracker as a request.
Scripts = Various
Originally posted by enigmatheatre View PostThere's always someone who will not like something. Its not like you are sitting looking at it all day. You will use it once every now and then.
- Likes 1
I did add it to a tracker (HSCS-187) and obviously you don't stare at this all day. But none of that is the point. In this day and age things like that shouldn't happen.
What happens when a new user tries the UI and spots something like this. The first thing they say is rookie and they assume the worst for the rest of the application.
