I had the problem with a new v4 Z-Net as well.
EVA LOgik ZW97
Originally posted by George View PostThis unit used to be the Inovelli Dual Outdoor Socket NZW97. If you look at the Inovelli support forums you'll see that Eric (the owner) had a falling out, his words, with the manufacturer and discontinued it in 2018. Amazing that it's still called the 97. Inovelli ended up issuing RMA's and refunding a lot of them and never got them to work correctly. Probably the reason for the 'falling out'.
It's now being sold under the EvaLogic name (most likely a Chinese brand) on Amazon. Considering the firmware is still low at 1.1, my bet is that it's still has the same issues as the ones sold in 2018. There are some reports that someone dug up a custom driver for the Samsung Smartthings hub that seemed to recognize it. But no dice for other systems.
Just go over to the Inovelli forums and search for NZW97 and you can read all about it.
There was a NZW97 on eBay a couple of week ago and considered biding on it but when I saw that the latest bid was only $4.95 and it was only 6 hours to go, I decided to do some research on it. Glad I didn't bid on it because they wanted $14 or so, bucks in shipping. Not a great deal when you add the two together so I passed."if I have seen further [than others], it is by standing on the shoulders of giants." --Sir Isaac Newton (1675)
No response from Eva Logik (aka Nie_tech Co, Ltd.) so I'm packing it up and sending it back to Amazon. I'm going to add a z-wave switched outlet instead once the rainy weather subsides.
I purchased one of these based on fairly good reviews on Amazon. This is my first z-wave device & it was a pian to configure. Perhaps that was because I am still figuring things out in Homeseer. I believe everything is working a now & hopefully it still will after unplug it & take it outside. I do have a couple of questions.
1. Under devices I have a HS-ZWPB700 (148) but there is no status. What is this?
2. I see my plug but I have to click on it to show both switches. Is this normal or is there a way for this to show as two separate devices?
Refer to the pictures it that helps2 Photos
Originally posted by jadesse View PostI purchased one of these based on fairly good reviews on Amazon. This is my first z-wave device & it was a pian to configure. Perhaps that was because I am still figuring things out in Homeseer. I believe everything is working a now & hopefully it still will after unplug it & take it outside. I do have a couple of questions.
What you are seeing is a "root" device called "Front Outdoor Plug" with the first feature showing. When you click on the "card" you see all of the features. When you look at it in list view and it makes more sense.
EDIT: The "HS-ZWPB700" is your USB Z-Wave interface. It has no features so doesn't show a status. Again, not very useful."if I have seen further [than others], it is by standing on the shoulders of giants." --Sir Isaac Newton (1675)
Originally posted by kenm View Post
In my experience with HS4, grid view has never worked correctly for most (all) of my devices. It seems random as to what controls and status show up on the "card" and, unlike list view, you can't edit the status nor controls.
