Multipoint Association not working in HS4
    In HS3, I had one of the newer firmware Qubino dimmers working with multipoint association.
    Association group 5 and 6 map to HS endpoint 2 (input 2), association groups 8 and 9 map to HS endpoint 3 (input 3).
    This worked in HS3, and the devices are still there in HS4- but input 2 doesn't change and no log created.
    I know the dimmer is still sending the endpoint 2 message as can see them on an association to secondary Zway controller.
    If I run an audit and rescan Homeseer also creates association groups 2 and 3- but these association groups are nothing to do with input 2/ 3 on Qubino.
    Have tried deleting and recreating association groups- no change
    In the zwave page the rescan, replace, remove buttons are also intermittently coming up as question icons- see second screenshot
    Is there a way to debug zwave messages being received?
    Click image for larger version  Name:	1.PNG Views:	0 Size:	324.6 KB ID:	1420908
    Missing buttons:-
    Click image for larger version  Name:	2.PNG Views:	0 Size:	139.9 KB ID:	1420910
    What version of HS4 are you using.
      4.1.4.0
        Good pointer, I thought I was fairly up to date, but tried 4.1.7.0 and issue gone
          I spoke too soon. Multipoint associations for one dimmer started working after upgrade to 4.1.7.0- but two identical dimmers are no longer reporting i2/ i3.
          All were previously working reliably in HS3
            Moving this to main HS4 as not Beta... issues continue with 4.1.8.0
              Any updates on this issue?
              I have two devices (Heatit z-push wall switch and Fibaro Double Switch 2) that was multi endpoint associated using Fibaro HC2, and this worked fine. Now, I´m trying the same in HS4 but the devices act like they´re not devices capable of multi endpoint associations.
              Cannot figure out why, HS4 software or UZB1-stick? I´m pretty sure it´s not the devices.
                Sorry, ai never got anywhere with this- too busy and on a pending pile...
                  Ok. I submitted a ticket...if I get an answer I´ll post it here. Based on discussions in other forums best guess is a bug in the z-wave plug-in...
                    Any Luck with this I am having Problem I upgraded Zwave Plugin and now any new associations I set wont work any I set prior to upgrade still work is it possible to get the HS3 Zwave Plug in
                      At some point it started to work…possibly due to a fix in one of the releases. Hodeverk, no explaination etc.
