HS4 Beta 4.1.100.0 (4.2 Beta) is available
    #61
    Originally posted by John245 View Post
    I do not have a hs4stop.sh
    John
    This is what the systemd service calls to shutdown hs. Sorry for the lack of info.
      #62
      rjh
      Preventing of finding the system is not working.
      John
        #63
        Camera recordings not showing, URL is messed up again
        recordings.html?viewdate=8/6/2021 should be recordings.html?viewdate=6/8/2021
        System = windows
          #64
          How did you test this? It will take some time for the system to get removed from the server so check it after a few hours and it should be gone.
          rjh
          John
            #65
            Are you on Windows? What are your regional settings set to? Looks like we may not be honoring that.
            I have an open issue to be fixed in the next update that deals with date/time formats for the camera recordings page so this may be the same issue.
            System = windows
              #66
              I just enabled the thick box and refreshed the find.homeseer.com page..
              I understood that it will take time. Tested now (after 5 hours) and still no success. Will try again tomorrow.
              John
                #67
                System = windows
                Settings: Europe date and time 24Hrs
                See also ticket HSCS-6625
                In the previous beta version it was ok..... (4.18.3)
                  #68
                  @rjh
                  On Ubuntu 20.04 LTS
                  Is it possible to access the Linux Tools? Should I use Ubuntu username an password?
Name:	linux tools.PNG
                  John
                    #69
                    rjh
                    John
                    In the past, this setting was effective only with myhs disabled as well.
                    I have a script to test the purge time (insert ten bogus entries into the table, then poll every 60 seconds until all he added entries disappear). Just now, all ten entries disappeared right about the twenty minute mark.
                      #70
                      Any valid user/pass on your system should work.
                      @rjh
                      On Ubuntu 20.04 LTS
                      John
                        #71
                        In that case I have an issue. Using the Ubbuntu credentials will result in " Warning Password ncorrect"
                        John
                          #72
                          rjh
                          What should happen in case I select the highlighted (yellow) icon.
                          I can not select. Under which conditions will it be selectable?
                          John
                            #73
                            rjh
                            Can you rewrite the Event page and make it look and feel like the features page.
                            I like the fact that I can drag and drop the features. Would be helpful if that is also possible with the event actions.
                            John
                              #74
                              rjh
                              Tooltips are missing for the yellow highlighted icons.
                              John
                                #75
                                The problem is with the check_passwd program in the HS folder, it's probably compiled for ARM. I will check and include one for X86. But if you have a different CPU you will need to compile the check_passwd.c file. Can you compile that file and see if you can then log in?
                                John
