zwolfpack you requested SteveW in this post https://forums.homeseer.com/forum/hs...99#post1494999 to start a new thread. As I did populate the hypothesis I will starting this thread.
I found the root cause for my system (during extensive testing 0n 4.2.0.0). Although I have no idea to fix.
I repeated the steps in this post
https://forums.homeseer.com/forum/ho...01#post1491401
also on 4.2.0.5 with identical results.
So the behavior of situation 1 and 2 differs
1. Upgrade after starting HomeSeer usig ./go PASS
2. Upgrade after starting Homeseer as a service FAIL (starting as a service following these directions: https://forums.homeseer.com/forum/ho...45#post1306645)
By the way In case of situation 1 when I do a reinstall of HomeSeer after the first successful upgrade it will alos fail. So my hypothesis is that during the upgrade process the instance is rebooted. In case you can confirm this we will know the root cause for sure.
Any idea how to fix?
John
John
