HS4 Beta 4.2.1.0 is available
    This build is being posted for testing and feedback. See the release notes for changes. This build includes some bug fixes and new features.
    If there are no significant issues with this build we will make this the next official public release.
    Release Notes
    A note about version numbers
    Starting with this release all versions will be in the format #.#.#.0. This indicates a public release (either Beta or formal). Release numbers ending with a value greater than 0, such as 4.2.0.9 are for internal HomeSeer testing, or possibly given to an individual to test.
    Installing:
    Before installing any Beta it is a good idea to back up your system! Run the backup from the tools menu. On Windows you can simply copy the HS4 folder to another folder. Just copy it back if needed.
    * You can install this Beta from within HS4, just go to the General page in Setup (Windows or Linux)
    If you would like to manually install the Windows version, the installer is here:
    https://homeseer.com/updates4/SetupHS4_4_2_1_0.msi
    The Linux tar file is here, or install from setup:
    https://homeseer.com/updates4/linux_4_2_1_0.tar.gz
    Reverting to a previous version on Windows:
    Uninstall HS4 (it will not remove any config files, plugins, etc.). Then install your previous version and install into the same folder as your previous install.
    Reverting to a previous version on Linux:
    On the PI-HUB/ZEE S2/SEL or your own Linux install. You can simply re-install the release version from setup.
    πŸ’‍♂️ Support & Customer Service πŸ™‹‍♂️ Sales Questions πŸ›’ Shop HomeSeer Products
    rjh ,
    Can we have s refresher on how to install especially on Linux.
    A lot people get confused and at times lash out on those who try help...
    Eman
      rjh Rich, in grid view, I see the icons at the top of the card just show the device status. As there is no device name, it is difficult to understand what these relate to? Surely it should be set to show the device name plus the device status for these? Tooltips allow new lines so it should be easy to add?
      Jon
        We have a doc here, if this needs any updates, I can update it:
        https://docs.homeseer.com/display/HS...g+HS4+on+Linux
        Originally posted by Eman View Post
        rjh ,
        Eman
          Yes, I will add a request to add the device name.
            This bug, which has me dead in the water for my project is still not working in this version (Not sure if it was supposed to be fixed in this release or not)
            RJ_Make On YouTube
              Thst's right!
              But more on about upgrading from HS3 to HS4 especially the Raspberry Pi devices or else eveything in general about Linux upgrades.
              Eman.
                Small issue when you resize the window width too small, the search box in the upper right-hand corner changes to a yellow "Test 1" icon. Pic below. And, YES, please, updated Linux instructions.
                  That has nothing to do with the Homeseer build. That is Jon00 Links. Go to Widgets setup and look for 002 - Mobile Test and if necessary disable.
                  Jon
                    There is an issue with VBC vs VBNC. from the HS4 docs = Vbnc is deprecated and will be removed in future updates, use vbc instead.
                    Also, a reminder to check for the correct MONO version and istall the updated MONO version. Initial Linux install loaded V4 when V6 is needed.
                      We have a Linux upgrade doc here:
                      https://docs.homeseer.com/display/HS4/Linux
                      Let me know what is missing and I can update the docs.
                      Thst's right!
                      Eman.
                        πŸ‘πŸ‘πŸ‘ Fixed - thanks!
                          I’m seeing this as well on an iPhone. Is there a way to disable it on an iPhone? Doesn’t seem to be appearing on my iPad so I assume it has to do with a smaller screen? Thanks Jon.
                          HS4 4.2.6.0 &HSTouch Designer 3.0.80
                          Plugin's:
                          weatherXML, Jon00 Alexa Helper, Network Monitor, MyQ, Z-Wave
                            Smashing!
                            I got this!...Will link it.
                              Upgrading from v4.2.0.8 beta to 4.2.1 beta has overwritten my startup.vb file with a default startup.vb. Is this by design or a bug?
                              (Upgraded with the SetupHS4_4_2_1_0.msi file)
