HS4 Beta 4.2.1.0 is available
Originally posted by rjh View PostMade the change. I like your "simple" suggestions, really fine tuning here!
Also, Window Covering would be a good addition as a default category ๐
Is anyone getting similar errors in the log since 4.2.1.0 from the built-in HS backup scheduler?
LINUX
9/23/2021 11:10:00 AM HomeSeer Error Scheduled backup did not run: Object reference not set to an instance of an object
9/23/2021 11:09:00 AM HomeSeer Error Scheduled backup did not run: Object reference not set to an instance of an object
I tried it manually and confirmed the problem:
Originally posted by avpman View PostIs anyone getting similar errors in the log since 4.2.1.0 from the built-in HS backup scheduler?
SOLVED - turned out to be a network error saving backup to a NAS. Not a very helpful error message.
LINUX
Build 4.2.2.0 has been posted.
https://forums.homeseer.com/forum/hs...0-is-available
- Likes 1
I updated my table and removed the ones that are fixed.
Issue# Issue type Description Status Criticality Link(s) Comment(s) 2 Bug Re-install on Ubuntu 20.04 LTS will not restart HomeSeer Open Critical https://forums.homeseer.com/forum/hs4-products/hs4-software/hs4-pro-beta-releases/1485173-hs4-beta-4-1-100-0-4-2-beta-is-available?p=1487730#post1487730 Other users has the same issues, see post 48 5 Bug Consistent use of capital letters Open Minor https://forums.homeseer.com/forum/hs4-products/hs4-software/hs4-pro-beta-releases/1485173-hs4-beta-4-1-100-0-4-2-beta-is-available?p=1487774#post1487774 7 FR Addition of multiple select for display type Open Minor https://forums.homeseer.com/forum/hs4-products/hs4-software/hs4-pro-beta-releases/1485173-hs4-beta-4-1-100-0-4-2-beta-is-available?p=1487852#post1487852 8 Bug More than 5 status only devices can be selected for the grid view Open Major https://forums.homeseer.com/forum/hs4-products/hs4-software/hs4-pro-beta-releases/1485173-hs4-beta-4-1-100-0-4-2-beta-is-available?p=1487860#post1487860 Fixed in 4.2.1.0 beta 11 FR Tooltips missing for icons device feature page Open Minor https://forums.homeseer.com/forum/hs4-products/hs4-software/hs4-pro-beta-releases/1485173-hs4-beta-4-1-100-0-4-2-beta-is-available?p=1488042#post1488042 12 Bug No action will be executed when pressing the icon with 9 squares on the device feature page Open Major https://forums.homeseer.com/forum/hs4-products/hs4-software/hs4-pro-beta-releases/1485173-hs4-beta-4-1-100-0-4-2-beta-is-available?p=1488034#post1488034 13 FR Rewrite Event page to look and feel of the feature page Open Major https://forums.homeseer.com/forum/hs4-products/hs4-software/hs4-pro-beta-releases/1485173-hs4-beta-4-1-100-0-4-2-beta-is-available?p=1488037#post1488037 15 FR Change naming Logging under device features and bulk edit Open Minor https://forums.homeseer.com/forum/hs4-products/hs4-software/hs4-pro-beta-releases/1494659-hs4-beta-4-2-0-5-is-available?p=1495074#post1495074 Reported based on testing v4.2.0.5 beta 16 FR/bug Improve alignment feature names in case of long names Open Minor https://forums.homeseer.com/forum/hs4-products/hs4-software/hs4-pro-beta-releases/1497928-hs4-beta-4-2-1-0-is-available?p=1498030#post1498030 Reported based on testing v4.2.1.0 beta 17 FR Add fixed โSaveโ and โCancelโ button at the bottom of applicable pages to be consistent with the device feature page Open Minor https://forums.homeseer.com/forum/hs4-products/hs4-software/hs4-pro-beta-releases/1497928-hs4-beta-4-2-1-0-is-available?p=1498034#post1498034 Reported based on testing v4.2.1.0 beta 18 Bug On device page button is called โCategoryโ on the page it is named โCategoriesโ Open Minor https://forums.homeseer.com/forum/hs4-products/hs4-software/hs4-pro-beta-releases/1497928-hs4-beta-4-2-1-0-is-available?p=1498039#post1498039 Reported based on testing v4.2.1.0 beta
John
