This build is being posted for testing and feedback. See the release notes for changes. This build includes some bug fixes and new features.
If there are no significant issues with this build we will make this the next official public release.
Only a couple of fixes in this build over the previous one.
Release Notes
A note about version numbers
Starting with this release all versions will be in the format #.#.#.0. This indicates a public release (either Beta or formal). Release numbers ending with a value greater than 0, such as 4.2.0.9 are for internal HomeSeer testing, or possibly given to an individual to test.
Installing:
Before installing any Beta it is a good idea to back up your system! Run the backup from the tools menu. On Windows you can simply copy the HS4 folder to another folder. Just copy it back if needed.
* You can install this Beta from within HS4, just go to the General page in Setup (Windows or Linux)
If you would like to manually install the Windows version, the installer is here:
https://homeseer.com/updates4/SetupHS4_4_2_2_0.msi
The Linux tar file is here, or install from setup:
https://homeseer.com/updates4/linux_4_2_2_0.tar.gz
Reverting to a previous version on Windows:
Uninstall HS4 (it will not remove any config files, plugins, etc.). Then install your previous version and install into the same folder as your previous install.
Reverting to a previous version on Linux:
On the PI-HUB/ZEE S2/SEL or your own Linux install. You can simply re-install the release version from setup.
Release Notes
Installing:
