HS4 Beta 4.2.4.0 is available
    #16
    This is strange. Using bulk edit, I select all in a particular category to be hidden. Then I go back and select the root and features I want un-hidden. Part way through the selection process, ALL the boxes get checked and I have to start over. I can't even complete the process.
    Also, when selecting all and then doing a bulk change of some sort, after it completes all the check marks are still in place except the one you have to check at the top to select them all. It should be checked as well, OR, all the check should be gone.
      #17
      rjh
      Under General/Setup is it possible to align the radio button correctly?
Name:	Capture general setup.PNG
      John
        #18
        rjh
        Under General/Setup the line for Max Days To keep is significantly shorter as the other lines on this page (except for log colors). Is there a specific reason?
Name:	Capture general setup log settings.PNG
        John
          #19
          John245 These niggling things annoy me as much as they do you. I just don't have the patience that you have. Thank you for reporting.
            #20
            rjh
            Why not "Latest Stable" as a Beta version is also a release?
            Furthermore I suggest (RE)INSTALL STABLE as in the case below it will be a downgrade
            Last, but not least. Why are there dots after BETA?
Name:	Capture update.PNG
            John
              #21
              I will note these. Bootstrap is frustrating with it's alignment. The alignment that you see if the default. I have to add spacing classes to get things to line up at times.
              Note that most of the UI changes you post are just changes in the .HTML files. I am totally open to anyone who wants to tweak these changes and give me the files. I can get the changes done much quicker. Just an idea. I can send you free stuff!
              Originally posted by John245 View Post
              rjh
              John
                #22
                If there are dots, it indicates that a dialog will display. So there should be dots after "REINSTALL UPDATE". Maybe the dots are not necessary on a button.
                rjh
                John
                  #23
                  I will check on this.
                    #24
                    rjh
                    Under backup and restore in case you select "Click here for more info" you would be directed to the MyHS login page. Then you need to login and can select the webpage. Why not a direction to that webpage?
Name:	Capture backup.PNG
ID:	1499945Click image for larger version
Name:	Capture click here.PNG
ID:	1499946Click image for larger version
Name:	Capture direct page.PNG
                    John
                      #25
                      Unfortunately I'm not a html guy.
                      John
                        #26
                        Yes, should probably go to the services shop page. I think the link was added before we completed the shop page. I will look into changing that.
                        rjh
                        John
                          #27
                          In the end this niggling things can have a big impact.
                          It would help if others report also these items.
                          John
                            #28
                            rjh
                            I know the 4.2 version will focus on the UIX. Do you have a deadline when the UIX improvements should be finished as I tend to only report 3 items each release.
                            John
                              #29
                              rjh
                              Why not use this symbol including tooltip to indicate that there are release notes? For me a button is more action related.
                              John
                                #30
                                I think UI improvements will continue. My plan is move on to some bigger features (like Dashboards) but I intend on posting updates regularly with smaller changes. For example, I will be working on compressing the device list view and event editor so its more compact for the desktop.
                                rjh
                                John
