HS 4.2.4.0 (linux) - Camera setup not working - Solved!
    I had my IP camera working with HS4 (only snapshot url) but after deleting I could not setup it again. I am unable to save the camera once added. I press save but nothing happens. When I click on another tab then I get a warning to continue configuring or discard without saving.
    The snapshot url I want to add:
    http://192.168.1.75/picture/1/current
    I also want to add the following streaming url, but that is not working too:
    http://192.168.1.75:8081
    Please also note when adding a new camera there is a suggested url preconfigured in the snapshot config field in a wrong format: http//
    Last issue; I am unable to save the enabled option "Save Recordings Locally".
    I have tried several browsers (safari, firefox, chrome), it makes no difference.
    I have this same issue. Still exists in 4.2.5.0
      I had contact with support, it seems to be a bug when MyHS is disabled. So the temporary workaround is enabling MyHS, make your changes and add cameras, then disable MyHS again.
