This build is being posted for testing and feedback. See the release notes for changes. This build includes some bug fixes and new features.
If there are no significant issues with this build we will make this the next official public release.
Biggest change in this release is that HS4 can now be run as a service on Windows. Please read the documentation on how to install and operate the service before you install. The docs are here:
https://docs.homeseer.com/display/HS...ice+on+Windows
See the release notes for all changes:
Release Notes
Installing:
Before installing any Beta it is a good idea to back up your system! Run the backup from the tools menu. On Windows you can simply copy the HS4 folder to another folder. Just copy it back if needed.
* You can install this Beta from within HS4, just go to the General page in Setup (Windows or Linux)
If you would like to manually install the Windows version, the installer is here:
https://homeseer.com/updates4/SetupHS4_4_2_7_0.msi
The Linux tar file is here, or install from setup:
https://homeseer.com/updates4/linux_4_2_7_0.tar.gz
Reverting to a previous version on Windows:
Uninstall HS4 (it will not remove any config files, plugins, etc.). Then install your previous version and install into the same folder as your previous install.
Reverting to a previous version on Linux:
On the PI-HUB/ZEE S2/SEL or your own Linux install. You can simply re-install the release version from setup.
Release Notes
Installing:
