This build is being posted for testing and feedback. We have done some internal code reorganization so we want to post this build with minimal changes to ensure that core functionality was not affected by the code modifications. We would appreciate you updating to this build and giving us some feedback. Make sure you back up your system before updating!
See the release notes for changes. This build includes some bug fixes and new features.
If there are no significant issues with this build we will make this the next official public release.
See the release notes for all changes:
Release Notes
Installing:
Before installing any Beta it is a good idea to back up your system! Run the backup from the tools menu. On Windows you can simply copy the HS4 folder to another folder. Just copy it back if needed.
* You can install this Beta from within HS4, just go to the General page in Setup (Windows or Linux)
See the release notes for download links.
Reverting to a previous version on Windows:
Uninstall HS4 (it will not remove any config files, plugins, etc.). Then install your previous version and install into the same folder as your previous install.
Reverting to a previous version on Linux:
On the PI-HUB/ZEE S2/SEL or your own Linux install. You can simply re-install the release version from setup.
