UPDATE 7/19/22: This build has been released as 4.2.14.0. You may update through setup or see the HS4 forum.
HS4 4.2.13.6 is ready for testing. See the release notes for all the changes. If there are no issues, this will be a 4.2.14.0 release.
All Changes: Release Notes
Installing:
Before installing any Beta it is a good idea to back up your system! Run the backup from the tools menu. On Windows you can simply copy the HS4 folder to another folder. Just copy it back if needed.
* You can install this Beta from within HS4, just go to the General page in Setup (Windows or Linux)
See the release notes for download links.
Reverting to a previous version on Windows:
Uninstall HS4 (it will not remove any config files, plugins, etc.). Then install your previous version and install into the same folder as your previous install.
Reverting to a previous version on Linux:
On the PI-HUB/ZEE S2/SEL or your own Linux install. You can simply re-install the release version from setup.
Installing:
