Scripts can access plugins so I think the script needs to run after everything else has been started. Sounds like you need a "pre-startup" script, something that runs before plugins are started. The init code before plugins are started does not take much time, most of the startup time is starting up scripts.
Note that there is an option on the Labs tab in Setup that allows plugins to start in the background. This might do what you want. If a plugin depends on another plugin, this might not work unless the plugin waits for its dependent plugin to start. Not sure there are many plugins that depend on other plugins.
Originally posted by Demusman
View Post
