HS4 4.2.17.3 is ready for testing. See the release notes for all the changes. If there are no issues, this will be a 4.2.18.0 release.
PLEASE READ THE RELEASE NOTES BEFORE INSTALLING THIS BUILD!
All Changes: Release Notes
When updating to this build the saved format of the events has changed. If you go back to a previous build of HS4 you will lose all of your event actions. Starting with this build your configuration is backed up automatically when you update to a new version of HS4. You can use this back up if you downgrade your installation. As always, do a full back up of your system just to be safe! You can backup from the tools menu in HS4. See the release notes for more details.
Installing:
Before installing any Beta it is a good idea to back up your system! Run the backup from the tools menu. On Windows you can simply copy the HS4 folder to another folder. Just copy it back if needed.
* You can install this Beta from within HS4, just go to the General page in Setup (Windows or Linux)
See the release notes for download links and instructions on how to revert to a previous version of HS4 if needed.
Installing:
