HS4 4.2.18.29 is ready for Beta testing!
    #16
    I can answer for me. When I press the Category button, a dialog appears showing me the Categories with a check box next to each. When I check one of the boxes and press Save the Devices page tries to display and shows all the headers etc but no devices are displayed. If you click on the Devices tab the devices will show with the filter correctly applied.
    Viewing as a list and no other filters applied.
    Here's the Devices page
Name:	Screenshot 2023-06-29 at 8.47.56 AM.png
    Press the Category button
Name:	Screenshot 2023-06-29 at 8.48.22 AM.png
    Select a single Category and press Save
Name:	Screenshot 2023-06-29 at 8.48.49 AM.png
    A blank screen shows. Press the Details button and all appears correctly.
    Date/time=6/29/2023 8:51:25 AM CDT
    Version=HS4 Standard Edition 4.2.18.29 (Linux)
    MONO Version=Mono JIT compiler version 5.20.1.19 (tarball Thu Apr 11 09:14:25 UTC 2019)
    License=Registered
    Confguration File=/usr/local/HomeSeer/Data/HomeSeerData.json
    Uptime=0 Days 10 Hours 34 Minutes 39 Seconds
    Lan IP=10.0.0.5 (hometrollerSEL)
    Device Count=171
    Event Count=110
    Plugins Enabled=PHLocation:,drhsIpPlugIn:,Z-Wave:,HS-WX200 Multi-Status:,EasyTrigger:,Pushover:
    Modules/Threads=68 Modules, 59 Threads
    Available Threads=199
    HomeSeer Memory Used=89 Mbytes
    Plugins Installed=drhsIpPlugIn 0.0.0.31,EasyTrigger 3.0.0.76,HS-WX200 Multi-Status 2.22.36.4,PHLocation 3.0.1.109,Pushover 4.0.12.0,Z-Wave 4.1.1.0​
      #17
      I found the problem with this (case sensitivity issue). If you are on Linux can you update to 4.2.18.30 through setup and see if the issue is fixed.
      Originally posted by PGN View Post
      Main Devices page,
      Problem first appeared in .20 but still present. Setting a change to the FLOOR selector and saving, causes the page to show ‘Error’. Refreshing the page, same issue. However, hitting Devices top left, page shows ok with correct updated FLOOR selection. Safari and Chrome.
      Date/time=6/27/2023 8:59:27 PM BST
      Version=HomeSeer HS4 ZEE S2 (Upg from HS3ZS2) Edition 4.2.18.29 (Linux)
      MONO Version=Mono JIT compiler version 6.12.0.122 (tarball Mon Feb 22 17:44:05 UTC 2021)
      License=Registered
      Uptime=0 Days 21 Hours 43 Minutes 20 Seconds
      Lan IP=192.168.0.23 (HS4PiV5)
      Device Count=469
      Event Count=157
      Plugins Enabled=Z-Wave Parameters:,Tuya:,Google Nest:,Sonos4:,Z-Wave:,AK GoogleCast:,ONVIF Events:
      Modules/Threads=114 Modules, 115 Threads
      Available Threads=398
      HomeSeer Memory Used=144 Mbytes
      Plugins Installed=AK GoogleCast 4.0.5.25,Chromecast 4.0.21.0,Google Nest 4.0.1.0,ONVIF Events 1.0.0.4,Sonos4 4.0.1.23,Tuya 4.0.39.0,Z-Wave 4.1.0.3,Z-Wave Parameters 4.0.55.0
      Disk Size=58.02GB​
        #18
        Perfect. .30 works for me. Thanks.
          #19
          bdickhaus PGN - does .30 fix your systems as well?
            #20
            Fixed in .30 for me also (on Linux.)
              #21
              We have released this build as 4.2.19.0, thanks to all for your feedback while testing!
                #22
                macromark rjh Yes. Thanks for fixing. (Sorry for delayed response; uk time and also stopped getting notifications re posts and subscribed topics, for some reason)
                  #23
                  Sorted my problem out with Notifications!
