Feature Requests
This is a sticky topic.
  • #76
    Originally posted by alexbk66 View Post
    Did you select to hide "Marked Devices"?
    You're correct. I had the hidden devices option enabled. If I do the hide Marked devices, they all are removed properly. Thanks for the .33 version. Having the checkboxes there makes it a "master" enabled/disabled page. Then, clicking on the google calendar link and then the AK Google Calendar tab gets you to the main settings for the plug-in. It's just too bad you couldn't display all that information on the config page instead since it makes sense that you would make all the changes there.
    • #77
      I added "Use" checkbox on every config page - Main Config, Google Calendar config and each calendar config.
      • #78
        From what i can see here 3.0.0.33 is out but the in the updater only 3.0.0.22 is available. I can't find the plugin in the Beta section either. Is it only me?
        • #79
          • #80
            That's so strange. I had 3.0.0.22 installed with update N/A. Checked the original location that you pasted and there it was, 3.0.0.33. I installed it over the old one and now I'm on the latest version. Thank you!
            • #81
              Yeah, I noticed too - Manage Plugins page doesn't show available updates - I will report to HST.
