Use a calendar event as trigger.
  • Use a calendar event as trigger.
    Hi Alex,
    Sorry for this silly question. While I understand the logic of creating calendar events based on triggered HS events... I was wondering how to do the opposite. I mean, put a calendar event on google to turn on something and then turn it off when the calendar event finishes.
    Is that feasible? If so...how? (Dummy versión please 😂)
    kind regards!
    PP
    Easy, it's in the Plugin description thread.
    You have four trigger options:
    1. Event Reminder
    2. Event Start
    3. Event End
    4. Number of events exceed some number
    Other options:
    1. Which calendar
    2. Event Name/Description/Location contains some words (optional)
    3. Trigger before some time (optional)
    And you can use Global variables - i.e. if you want to announce the event name via TTS "Calendar Event: $$GLOBALVAR:cal_ev_name: $$GLOBALVAR:time_to_event:"
      https://forums.homeseer.com/forum/in...23#post1299323
        Awesome!!
        Found the problem... for whatever reason there was no trigger on my HS3... restarted the plugin and here it is...
        Now that I have the triggers it kind of self explanatory!!! :P
        Thanks Alex!
        PP
          This is one of the nicest feature of the plugin !
          I mean yeah you can log all data you want in a database( sql or wtv) but having a userfriendly way of doing it is very welcome.. + you can't beat a google calendar when you think about if it is '' human redeable''
            Thanks guys!
              Hi Guys!
              Using a calendar event as a trigger functions but only the start... My first use is to turn on and off my espresso machine but only the ON works... Can't find what I did wrong... can you give it a look?
Name:	Screen Shot 2020-03-29 at 20.00.56.png
              Thank you!
              PP
                I think it's called RTFM?
                https://forums.homeseer.com/forum/in...27#post1299327
