Introducing AK Square plugin
This is a sticky topic.
    My plugins:
    Click image for larger version  Name:	ikea_64.png Views:	0 Size:	2.1 KB ID:	1421180​​
    AK IKEA
    Click image for larger version  Name:	Square64.jpg Views:	0 Size:	2.8 KB ID:	1421181​​
    AKSquare
    Click image for larger version  Name:	Bond64.png Views:	0 Size:	5.1 KB ID:	1421176​​
    AKBond
    Click image for larger version  Name:	Sonoff64.png Views:	0 Size:	5.6 KB ID:	1421182​​
    AKSonoff
    Click image for larger version  Name:	Shelly64.png Views:	0 Size:	6.5 KB ID:	1421184​​
    AKShelly
    Click image for larger version  Name:	gates  - 3.jpg Views:	0 Size:	93.7 KB ID:	1423325
    AKRemootio
    Click image for larger version  Name:	AKEnphaseEnvoy64.png Views:	0 Size:	8.7 KB ID:	1421179​​
    AKEnphaseEnvoy
    Click image for larger version  Name:	AKGoogleCast64.png Views:	0 Size:	1.5 KB ID:	1421178​​
    AKGoogleCast
    Click image for larger version  Name:	AKGoogleCalendar64.png Views:	0 Size:	3.4 KB ID:	1421177​​
    AKGoogleCalendar
    Click image for larger version  Name:	AKSmartDevice64.png Views:	0 Size:	6.0 KB ID:	1421183​​
    AKSmartDevice
    Click image for larger version  Name:	AKHeatmiserNeo64.jpg Views:	0 Size:	2.1 KB ID:	1421185​​
    AKHeatmiserNeo
    Click image for larger version  Name:	AKTracdown500 - New.png Views:	0 Size:	300.3 KB ID:	1423326
    AKTracdown
    Click image for larger version  Name:	Square.jpg Views:	0 Size:	41.7 KB ID:	1365099
    AK Square plugin allows to retrieve data in real time from the "Pay With Square" credit card processing platform.
    Click image for larger version  Name:	image_86607.png Views:	5 Size:	406.3 KB ID:	1365098 Click image for larger version  Name:	image_86606.png Views:	5 Size:	204.0 KB ID:	1365097
    Installation / Configuration
    Currently the plugin implements the authentication using the Developers Access Token for the application created via Developers Portal https://developer.squareup.com/apps. In the portal create an application, the Credentials tab will have the "Personal Access Token".
    Square recommend using Oauth2 authentication, so currently I'm working on implementing Oauth2 flow.
    1. After installing the plugin go to the plugin root device configuration page and enter the Access Token obtained from the Developers portal.
    Click image for larger version  Name:	Config.jpg Views:	0 Size:	76.2 KB ID:	1365103
    2. If authentication is correct - the devices will be created in HS. The blue icon denotes the payment received, the green icon - corresponding transfer to the bank account:
