[Feature Request] Allow pushover as notification source
  • [Feature Request] Allow pushover as notification source
    Would it be possible to allow for pushover notification of alerts instead of only allowing email?
    There is a plugin for pushover, and a large amount of folks are using it instead of email because it seems to work reliably as compared to email.
    You are correct, there is a plug in that works very well. Why reinvent the wheel?
    Sent from my SM-G935V using Tapatalk
      I believe the op is asking Bob to allow one to use the other existing pushover plugin from within BLLAN for notifications instead of email. Plugins can reference and use other plugins from within themselves. Much like you can often reference plugin features from scripts.
      Sent from my XT1585 using Tapatalk
      MeiAutomtion Home
        This is what I was requesting, my wording may have not been clear enough.
        Currently, you only have the option in the BLLAN plugin to send notifications via email.
        Originally posted by sirmeili View Post
        I believe the op is asking Bob to allow one to use the other existing pushover plugin from within BLLAN for notifications instead of email. Plugins can reference and use other plugins from within themselves. Much like you can offer reference plugin features from scripts.
          Oh, I see now. Sorry I misunderstood. That would be a useful enhancement!
            You could use an event and trigger off the device value
            I believe 0 = off and 100 = on
            Cheers,
            Bob
              Yes, here is an example
                But I have a larger than normal amount of devices, so I'd have 20-25 new "events" to do something that should be a somewhat easy fix at the head end.
                Also could be ported to your other plugins that report at the same time, so basically a module
                Pretty Please!
                  use pushover email alias
                  there is also an option to create email aliases for pushover devicegroups.
                  go to the pushover.net settings and section Create an Email alias and use this alias address
                  for pushover notifications. xxxxxxx@pomail.net
                  one disadvantage is pushover email delivery is little bit slower.
                  Zigmund
                    I send quite a few emails to xxxxxxxxxx@pomail.net and they are fast and reliable. The only delay (if there is any) is in the sending of emails, Pushover's sending the message is always quick. When I have tested with simultaneous sends they arrive within a second or two of each other. Here is a screenshot form an event that sends a Pushover message through the plug-in and another by email.
                    The email push message was delivered within 2 seconds of the Pushover direct.
                    Randy Prade
                    Aurora, CO
                    Prades.net
                      Yes, I know you can specify an email for pushover.
                      This doesn't fix an issue I've run into in that the "email chain" has broken for some reason and I don't receive the alert.
                      Having an alternate through the pushover plugin will give a 2nd path of an alert so if something is broken in the email chain, I'd still receive the alert.
                      Unless someone broke the internet
