Help
  • Help
    I'm have BLLAN set up to monitor several cameras which go off-line periodically. I have events set up to recycle the power to get them back on-line. But using the value of the BLLAN device going to 0 never triggers the corresponding event. Am I missing something? Shouldn't the change in the BLLAN device be able to trigger events just like any other device?
    Thanx
    I can't specifically help you here. But I have noticed that your subject lines don't reference your issues. I'd suggest adding a bit in there so we can see at a glance your issues.
    Jim
    Plugins:Z Wave 3.0.1.55, HS3 Pro 3.0.0.208, HS3Touch, HS3Touch IOS, Z-Net, SceneMaster, XBMC, Sonos, Media Controller, Envisalink (52 Virtual nodes), JowiHue, EasyTrigger, Liftmaster MyQ, BLBackup, BLLAN, BLRadar, Pushover
    Devices:Cooper RF9540, Cooper Scene, Yale Locks, Sonos, Phillips Hue and Lux, DSC, Somfy Blinds
      I will take a look at the code
      Cheers,
      Bob
        The device should change to 0 for Off and 100 for On
        Cheers,
        Bob
          Please confirm, to determine if the cams are online or offline you are using BLLAN to ping the device?
            yes. Using BLLAN to ping the cams. After several failures, the BLLAN value changes to 0. Have several events set up to run when a BLLAN device changes to 0. But none of the events ever trigger
              Post a screenshot of your event
              Cheers,
              Bob
                  Here's a screenshot. 21-Camera Basement CrittersCam1 (and 2) is a BLLAN device and 22-Camera Basement CritterCams Power is an appliance on/off module supplying power to the two cams.
                    Does anyone have an idea how I can fix?
                    Thanx
                      Thanx
                      if you are running blue iris and plug in it is an easy fix... when the camera has no signal toggle a switch and it restarts. I have one that is a problem, and I set it up as above. the camera probably needs to be replaced, but I will wait until it is totally gone...
                        Did you read my posts? I know that cycling the power fixes it. The problem is that when BLLAN see s the cam offline it never triggers the event to cycle the power.
                          I have had trouble with 'Or if' statements in events.
                          Have you tried removing the 'or if' and using one cam per event to fail and trigger the switch?
