Linux Install images
  • Linux Install images
    Just noticed that the default image directories for status in Linux are incorrect.
    To fix this I just changed the directory reference upper case to lower case images.
    [ATTACH]66313[/ATTACH]
    Is there a way to edit the device address or can I just change it via the database?
    Below I would like to change the BLLAN003 to BLLAN001
    [ATTACH]66314[/ATTACH]
    - Pete
    Auto mator
    HS4 Pro - V4.0.5.0 - Ubuntu 18.04/W7e 64 bit Intel Kaby Lake CPU - 32Gb - Mono 6.8X
    HS4 Lite -
    I will check the install for Linux and get that fixed
    You should be able to change it in the database
    Just make sure you do not have 2 with the same address
    Cheers,
    Bob
      Thank you Bob.
      - Pete
      Auto mator
      HS4 Lite -
        Updated to BLLAN V.2.0.39.0 and all looks fine.
        Thank you Bob.
        - Pete
        Auto mator
        HS4 Lite -
          Wrong Image path
          Hi,
          Did a fresh install of Linux version and still has the same Image default path with BLLAN V.2.0.39.0 (no other version ever installed). I had to change the Image to image to get it to work.
          I am using Docker container cbolt/homeseer:latest on a QNAP NAS.
