Unable to upgrade plugin from 2.0.73.0 to 2.0.84.0
  • Unable to upgrade plugin from 2.0.73.0 to 2.0.84.0
    I've attempted to upgrade the plugin from version 2.0.73.0 to 2.0.84.0, and no matter what options I attempt, I get the same issue as seen below:
    Sep-25 23:22:56 Updater Install/Update of package BLStat failed.
    Sep-25 23:22:56 Updater Error Installation of package BLStat failed. Try disabling the plugin first, then re-try the update.
    Sep-25 23:22:56 Updater Installing package BLStat
    Sep-25 23:22:56 Updater Update hspi_blstat.exe downloaded successfully
    Sep-25 23:22:53 Updater Downloading update: BLStat
    Sep-25 23:22:53 Updater Starting download of updates
    Sep-25 23:22:44 Info Plugin BLStat with instance: has disconnected
    Sep-25 23:22:41 Plug-In Shutting down Plug-In: BLStat
    This did happen once before, and I don't remember what we did to get it unstuck. It's on a linux install.
    Logon to the linux box and run this:
    ps -ef | grep BLLAN
    Paste in the output of this
    Cheers,
    Bob
      root 2730 2667 19 00:23 ? 00:00:33 /usr/bin/mono /opt/Homeseer/HSPI_BLLAN.exe
        Execute this command:
        kill 2730
        If that does not kill it, then do this:
        kill -9 2730
        Cheers,
        Bob
          Worked perfectly! Odd that the on/off slider in HS3 didn't actually shut it down.
          Thank you Blade.
            Hmmm, appears that you were trying to update BLStat, but you killed BLLAN ???
              Well, um, hmm... guess my brain must have inserted the correct PID because it worked
              And I failed to post in the correct forum
