Unable to upgrade plugin from 2.0.73.0 to 2.0.84.0
  • karib
    Well, um, hmm... guess my brain must have inserted the correct PID because it worked
    And I failed to post in the correct forum
  • zwolfpack
    Hmmm, appears that you were trying to update BLStat, but you killed BLLAN ???
  • karib
    Worked perfectly! Odd that the on/off slider in HS3 didn't actually shut it down.
    Thank you Blade.
  • Blade
    Execute this command:
    kill 2730
    If that does not kill it, then do this:
    kill -9 2730
  • karib
    root 2730 2667 19 00:23 ? 00:00:33 /usr/bin/mono /opt/Homeseer/HSPI_BLLAN.exe
  • Blade
    Logon to the linux box and run this:
    ps -ef | grep BLLAN
    Paste in the output of this
  • karib
    started a topic Unable to upgrade plugin from 2.0.73.0 to 2.0.84.0
    I've attempted to upgrade the plugin from version 2.0.73.0 to 2.0.84.0, and no matter what options I attempt, I get the same issue as seen below:
    Sep-25 23:22:56 Updater Install/Update of package BLStat failed.
    Sep-25 23:22:56 Updater Error Installation of package BLStat failed. Try disabling the plugin first, then re-try the update.
    Sep-25 23:22:56 Updater Installing package BLStat
    Sep-25 23:22:56 Updater Update hspi_blstat.exe downloaded successfully
    Sep-25 23:22:53 Updater Downloading update: BLStat
    Sep-25 23:22:53 Updater Starting download of updates
    Sep-25 23:22:44 Info Plugin BLStat with instance: has disconnected
    Sep-25 23:22:41 Plug-In Shutting down Plug-In: BLStat
    This did happen once before, and I don't remember what we did to get it unstuck. It's on a linux install.
