System Crash
  • #16
    I cannot duplicate the issue here. I automatically restart HS every Sunday morning so it is up for 7 days and I have never had it crash.
    It is a known bug in .net and I am wondering if because I am running Windows 7 that the issue is resolved in the newer .net version.
    I was seeing the issue with XP occassionally but I have not seen it now in a long time.
    Cheers,
    Bob
    • #17
      There are lot of other issues with W7
      Hope you will find a workaround for this problem.
      My system was running well before the upgrade to HS 2.5.0.4
      There must be some changes in 2.5.0.4
      • #18
        I am running 2.5.0.1
        Cheers,
        Bob
        • #19
          Bob,
          I think Win7 will not solve this problem.
          Since the problem is .net 2 related and this will be the same in windows 7.
          or?
          • #20
            I am just saying that it has not heppened to me now in about 6 months or more.
            The only difference for me that I can think of was Windows 7.
            Cheers,
            Bob
            • #21
              FYI, I'm running XP professional with 1.0.6.0 with no issues
              • #22
                Hi,
                Interesting enough I'm getting the same problem as well. I like these BL plugin, I'm installing almost all of them including the CPU Advisor, could it be this plugin that is cause the problem and not the BLLAN?
                1/15/2011 3:36:51 AM
                Attempted to read or write protected memory. This is often an indication that other memory is corrupt.
                HomeSeer version: 2.5.0.1
                Source: mscorlib
                Target: Void ExecuteCodeWithGuaranteedCleanup(TryCode, CleanupCode, System.Object)
                Stack trace:
                at System.Runtime.CompilerServices.RuntimeHelpers.ExecuteCodeWi thGuaranteedCleanup(TryCode code, CleanupCode backoutCode, Object userData)
                at System.Threading.ExecutionContext.RunInternal(ExecutionConte xt executionContext, ContextCallback callback, Object state)
                at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
                at System.Threading.ThreadHelper.ThreadStart()
                Please specify what you were doing at the time of this error:
                • #23
                  It is a known issue when I researched it on the web.
                  What OS are you running?
                  I am running Windows 7 and I have not seen the in months.
                  Cheers,
                  Bob
                  • #24
                    Originally posted by aldo View Post
                    Hi,
                    For me the problem only occurs when BLLAN is running.
                    Installed DooNetwork and disabled BLLAN had an uptime of just over 3 weeks.
                    Had to restart Homeseer so I disabled DooNetwork and enabled BLLAN and after about 8 hours I was greeted by the memory error.
                    Now back to DooNetwork and everything if fine.
                    • #25
                      XP Professional SP3
                      • #26
                        Just an FYI, it seems to be crashing around the same time, with mine around 3:30 AM. I will disable it and see if it is happening again or not.
                        • #27
                          I encountered this problem after I upgraded to the latest version coming from version 1.0.4.0
                          I reverted back to 1.0.4.0 and the problem disappeared.
                          So this issue must be introduced in version 1.0.5.0 or later !!!!
                          /Rien
                          Rien du Pre
                          The Netherlands
                          Using:
                          Homeseer PRO latest HS4 BETA on a Raspberry
                          Plugin's:
                          RFXCOM, mcsMQTT, Z-Wave
                          • #28
                            Anyone know where I can get an earlier version? I'm currently on version 1.0.7.0 and having this crash issue happen almost every other day..
                            • #29
                              Hope these help you
                              http://dl.dropbox.com/u/3445051/BLLAN_1.0.3.exe
                              http://dl.dropbox.com/u/3445051/BLLAN_1.0.4.exe
                              TrOjAn
                              Deleted in 24 hours
                              • #30
                                Confirming
                                Hi Everyone,
                                I am just confirming I saw this too on a new Hometroller build, with BLLan on I would get the mscorlib error in a few hours of startup.
                                No BLLan and no problem.
                                Can we please get a repost of previous revisions?
                                thanks
                                Mark
