Is the plug-in developer still looking into this issue? I really like the plug-in and the older version(1.0.4.0) is not updating properly with some of my devices. I read where the use of hs.ping is not reliable..
System Crash
I am still trying to find the cause of this.
I do not see the issue at all on my machine. I have run all versions of the plugin and I do not see the crashes.
This is a bug in .net 2.0 where the vb.net is garbage collecting the ping object too soon and then when the code accesses it again it throws the error you are seeing. I will attempt a work around and see if it helps.
The issue is apparently resolved in .net 4.0 but I do not know when HS will be capable of using .net 4.0 compiled plugins.Last edited by Blade; November 21, 2011, 08:52 AM.
