Hi
I am in the process of trialing HS3Pro and your BLLAN & BLUPS plugins. I have them installed and they seem to be working well, however i am confused around event creation. I apologize if this is more around HS3 than specifically your plugin.
Firstly does your plugin have its own event triggers (either one, e.g. BLLAN Host goes online / offline, or BLUPS status on AC Power or on Battery Power) or has this kind of event trigger (rather than group trigger) been replaced by some other mechanism in HS3.
secondly, when i create hosts in BLLAN (as an example), i have two seperate hosts, one which i know is online, and another dummy host which does not exist so will always report pings as offline. When i look in the device properties the values and status always appear as 0, or 0 = OFF, regardless of the status of the host (e.g. offline or online). Is this something that is ment to happen or have I done something wrong along the way?
What is the best way to achieve event triggers for power changing to off or on (e.g. On Battery Power), or hosts going Offline or Coming offline with these plugins?
Thanks for your help , I look forward to giving BLRADAR a go when either the ACRF plugin is finished, or I can get XAP working between HS2 & HS3
Cheers,
Trav Hale.
Cheers,
Trav Hale.
